sagar8446
Xilin SDK 2016.4 platform shutdown
Job found still running after platform shutdown.  Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.cdt.ui.CUIPlugin$3
Im getting this error when launching from Vivado launch SDK. Please help me out with this problem.When i reboot also the same problem comes again.
arpansur
Hi @sagar8446,
  1. Are you seeing the same issue specific to a single workspace or other workspaces too?
  2. Are you able to launch SDK standalone?
Please attach the snapshot of the issue you are seeing.
Arpan
arpansur
Hi @sagar8446,
Arpan
