karvi_in
Xilinx EDK XPS stalls while generating bitstream
   I am trying to compile the basic peripheral test app on a Digilent Nexys 2 board with a Spartan  3E FPGA on Vista 32bit. I am on the administrator account.
   I get the following last few console lines
Running Xilinx Implementation tools..
   xflow -wd implementation -p xc3s500efg320-4 -implement xflow.opt -ise ../__xps/ise/system.ise system.ngc
Release 11.1 - Xflow L.33 (nt)
Copyright (c) 1995-2009 Xilinx, Inc.  All rights reserved.
xflow.exe -wd implementation -p xc3s500efg320-4 -implement xflow.opt -ise
PMSPEC -- Overriding Xilinx file <C:/Xilinx/11.1/EDK/spartan3/data/spartan3.acd>
with local file <c:/Xilinx/11.1/ISE/spartan3/data/spartan3.acd>
.... Copying flowfile c:/Xilinx/11.1/ISE/xilinx/data/fpga.flw into working
directory G:/Electronics/FPGA/EDK_Projects/Test1/implementation
Using Flow File: G:/Electronics/FPGA/EDK_Projects/Test1/implementation/fpga.flw
Using Option File(s):
 G:/Electronics/FPGA/EDK_Projects/Test1/implementation/xflow.opt
 It seems to stall right after this. The process progress indicator continues animation, but there is no CPU activity for XPS.
I kindly request someone to help me out.
Thanks and Regards,
Karthik
karvi_in
Solved! Seems to be an acess rights problem. It works from a thumb drive; a related solution i found on this forum. If I copy the project folder back to the hard drive and use "Update Bitstream", it7 still works.
I have only the Xilinx Cygwin. I might upgrade to Windows 7 and see if its better.
karvi_in
Anonymous
Not applicable
Hi!
I've got the same problem on Windows 7 but still cannot solve it.
Could you tell me more details about what exactly you have done?
karvi_in
Sorry, its been a while since I had this prob and I dont remember this very well. But I believe starting Xilinx as an administrator fixed the problem.There is a similar post on this forum which might help you.
xiaofeip_dup
Please check out AR35351, http://www.xilinx.com/support/answers/35351.htm.
Felix
