Xilinx EDK - use new parser on old devices
I am using a V5 FPGA board and am back-porting logic that is tested to work on a V6.
How can I direct XST to use the new parser for V5 instead of the old parser ? What settings file should I change to achieve this ?
RRS
Tags (3)
Re: Xilinx EDK - use new parser on old devices
You can use the switch -use_new_parser yes in additional command line options of synthesis properties. After setting this in synthesis properties re-run synthesis.
Deepika.
Deepika.
Can you do this Xilinx Platform Studio ?
The one I have mentioned is in ISE.
For XPS, please follow the steps below:
1. Open the .scr file in synthesis folder of top level.
2. Include this switch in the .scr file and save it.
3. Now run it in command line mode.
Deepika.
Deepika.
Doesn't the SCR files get regenerated everytime. Which means I will have to make the edits every time ?
Can this be done using XCF files ? I see some posts suggesting this but am not seeing it to work.
