Xilinx Get XAPP1170 Working on ZYBO Board in Vivado 2017.1
I've been trying to get XAPP1170 on a ZYBO board for a while now in Vivado 2017.1. The problem is that it was made in VIvado 2015 for ZC702 instead of a ZYBO, so I've been trying to port it over. At first I thought you could just upgrade and convert everything to Vivado 2017, but I ended up getting blackbox errors because the IP was made for the ZC702.
Here's what I've done so far:
1) Used VIvado HLS to generate the Matrix Multiplication Accelerator IP specifically for the ZYBO board.
2) Changed the project to generate code for the ZYBO board and updated IP.
3) Disconnected all pins on the ZC702 version of Matrix Multiplication Accelerator IP.
4) Deleted ZC702 version of Matrix Multiplication Accelerator IP.
5) Placed ZYBO version of Matrix Multiplication Accelerator IP onto block design.
6) Connected all pins of the ZYBO version of Matrix Multiplication Accelerator IP to their corresponding IP's.
7) Went to validate design. Got error about HLS_Accel memory block not being mapped onto P7.
8) Assigned address to missing address block.
9) Validated design.
10) Generated bitstream.
11) Deleted .sdk folder.
12) Exported design with bitstream.
13) Generated .hdf and .bsp for project.
14) Manually put in main.c, platform.c, platform.h, lib_xmmult_hw.c, lib_xmmult_hw.h, and platform_config.h.
15) Manually changed macros with ...HLS_1... to ...HLS_0_...  to reflect the xparameters.h file that was generated.
The project will compile and run, but I get no output on the console.
The only clue I have right now is a warning I got:
missing initializer for field 'HandlerTable' of 'XScuGic_Config {aka struct <anonymous>}' [-Wmissing-field-initializers]    xscugic_g.c    /MMultAccel_7_5_17_bsp/ps7_cortexa9_0/libsrc/scugic_v3_6/src    line 53    C/C++ Problem
This is the definition of the struct:
typedef struct
    u16 DeviceId;        /**< Unique ID  of device */
    u32 CpuBaseAddress;    /**< CPU Interface Register base address */
    u32 DistBaseAddress;    /**< Distributor Register base address */
    XScuGic_VectorTableEntry HandlerTable[XSCUGIC_MAX_NUM_INTR_INPUTS];/**<
                 Vector table of interrupt handlers */
} XScuGic_Config;
and this is what was generated for xscugic_g.c:
#include "xparameters.h"
#include "xscugic.h"
* The configuration table for devices
XScuGic_Config XScuGic_ConfigTable[XPAR_XSCUGIC_NUM_INSTANCES] =
        XPAR_PS7_SCUGIC_0_DEVICE_ID,
        XPAR_PS7_SCUGIC_0_BASEADDR,
        XPAR_PS7_SCUGIC_0_DIST_BASEADDR
So it looks like XScuGic_VectorTableEntry HandlerTable[XSCUGIC_MAX_NUM_INTR_INPUTS] didn't get generated, and I don't know where to go from here.
Can anybody get this running on their ZYBO board?
You can download my project, along with the original XAPP1170 source and the pdf of the Xilinx Lab here:
https://github.com/electricbluefire/MMult/archive/master.zip
stephen.taylor
I've seen the same missing initializer message on multiple tutorials under 2017.2... it does not appear to stop the designs from working however.
