Xilinx LabTools 14.7 silent install
I am trying to install LabTools 14.7 silently using the xsetup.exe so I can deploy it via SCCM. Any ideas on how this can be done or what the command line switches are?
Thank you.
First up, I dont know, but I know others will jump in here.
BUT
You might want to tell them what OS you want to install on ,
also remember that ISE does not work on Windows 10. on W10, it has to run in a VM, with either W7 or a supported Linux,
Xilinx do ( now ) provide a VM wrapped version of ISE for just this ,
Its is mentioned about a "batch" install option in this document.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-ise-vm-windows10.pdf
