Xilinx SDK 2013.4 crashes after launch
Hello everyone!
Here's the problem:
I'm using Vivado 2013.4. After generating bitstream I select "Export Hardware for SDK" and pick "Launch SDK". SDK launches but crashes seconds after launch with this error (see attached file).
Java version is 7 update 67 (newest).
Windows version is 7 x64.
Has anyone met this? I guess I have to add some flags to eclipse.ini or something.
Well, I tried to launch the same project on another computer with the same Windows and Vivado versions and SDK also crashed.
So I just deleted the <project>.sdk folder and did it again and now it's o'k.
UPD: rebooting or reinstalling Java and Vivado didn't help.
Are you able to invoke SDK standalone?
Which version of java are you using?
Try updating the java to latest version.
Vinay
Yes, I'm able to launch SDK from Start menu and choose any workspace and it works. This error occurs only after exporting hardware for SDK with choosing Launch SDK.
My Java version is 7 update 67 (latest). And the error started occuring only after this update.
Is hardware being exported? You can check this by confirming whether "project_name.sdk" folder is created.
Also invoke vivado by using the following command: vivado -jvm Xmx4096m
Vinay
Yes, hardware export works o'k.
So where shall I type that command?
UPD: well, now it started to crash every time I build project. Not funny at all.
Follow below steps:
1. Open Command Prompt
2. Navigate to Vivado installed directory
3. Run the command: settings64.bat
4. Then run the command: vivado -jvm Xmx4096m
Vinay
That doesn't help. SDK still crashes.
