Observer chepner
Xilinx SDK 2017.4 Invalid Linux Tolchain Path
I'm using Xilinx SDK 2017.4 and I want to link it to my Linux generated with Yocto project.
The rootfs is accepted but ..
When I set Linux Toolchain to : /Xilinx/SDK/2017.4/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin
SDK say "Invalid Linux Toolchain Path" and refuse to go forward.
Any heklp please ?
Re: Xilinx SDK 2017.4 Invalid Linux Tolchain Path
Hi @chepner
You just need to remove the "bin" folder from the given path. If you just scroll to the "mini help" icon within the menu it gives you an example of how it should looks like.
Ibai
Ibai
Hi @chepner
Ibai
Ibai
Observer chepner
hi @ibaie,
Yes. I've seen it now. it work. Thanks
Marwen
