Participant sktpin
Xilinx SDK - Debug BSP source
I am debugging a MicroBlaze project, and get stuck in XSpi_Transfer.
To see why, I'd like to debug, i.e. step through, the library code.
I found this thread:
https://forums.xilinx.com/t5/Embedded-Development-Tools/Xilinx-SDK-IDE-Enable-Debug-With-BSP-Sources/m-p/751507#M41251
It mentions to change the optomization level for the whole BSP.
That would then not fit into the memory anymore, and I can't currently easily increase it.
So I used GCC __attribute__ optimization to set ot to level 0, only for the XSpi_Transfer function.
Now I am debugging, but it is still showing only the disassembly, not the C source code.
How can I step through the C source code?
Re: Xilinx SDK - Debug BSP source
HI @sktpin
You might want to refer to AR#69084
Basically go into the BSP settings and add the option -g to the extra compiler flags option. No need to set the optimization level to 0
HI @sktpin
Participant sktpin
Ah, right! Thanks. For anyone also reading this & with the problem of scratching at the program memory boundaries: "-g1" instead of "-g" will compile it with "minimal debug information", I didn't find what exactly that entails vs. the default, but it made the difference for me wrt the program fitting in the memory vs. not, and I can step through it (maybe not perfectly everywhere, haven't tried too extensively yet).
