Anonymous
Not applicable
Xilinx SDK Run and Debug Configuration
There are same options under run configuration and debug configuration in Xilinx SDK 2017.3. Both have GDB, QEMU, and System Debugger options. What is the difference between these options under run configuration and debug configuration ? and which document is describing them ? I have already checked UG1145.
ritakur
No difference, these are the same.
If you use debug configuration, PC will stop at main() and you can do step by step debug.
For more information, please check SDK help.
https://www.xilinx.com/html_docs/xilinx2018_2/SDK_Doc/index.html
ritakur
