Xuint32 Bug in SDK 14.6 Prevents Project Building
This bug has occured for tools 14.6. When creating a custom perh in CIP with drivers, the known bug http://www.xilinx.com/support/answers/54352.html still occurs. Further to this I have had issue building projects due to the use of the depreciated Xuint32 type which is still present in the driver c code.
As such to fix this in projects follow AR54352 and then in the driver code search and replace all instances of Xuint32 with u32.
Tags (3)
Re: Xuint32 Bug in SDK 14.6 Prevents Project Building
So this helped me out but I need to add that there are some more things that need to be modified depending on how you have built your custom peripherals.
Xuint32 = u32
Xuint16 = u16
Xuint8 = u8
Also there is may be _attributes_ that pop up just replace Xuint* = u*.
