05-05-2019 08:24 PM
I followed this:
https://www.youtube.com/watch?v=VjYdNIOyRcE
And I got this error:
ERROR: [IP_Flow 19-3188] Error occurred while initializing 'mb_subsystem_clk_wiz_1_0' Tcl error in update procedure while setting value 'MMCM' on the parameter 'PRIMITIVE'. FALSE ERROR: [IP_Flow 19-3428] Failed to create Customization object mb_subsystem_clk_wiz_1_0 CRITICAL WARNING: [IP_Flow 19-973] Failed to create IP instance 'mb_subsystem_clk_wiz_1_0'. Error during customization. ERROR: [BD 41-1712] Create IP failed with errors ERROR: [BD 5-7] Error: running create_bd_cell -vlnv xilinx.com:ip:clk_wiz:6.0 -type ip -name clk_wiz_1 .
05-12-2019 11:36 PM
Hi @tuan.nhanh ,
Which Vivado/SDK release are you using? The video seems to be quite old (2013.2) so I would not be surprised if something have been changed in the latest following releases that creates you the mentioned errors.
