Visitor werr4ever
ZCU111 Eval Board: Loading Bare Metal on Arm R5: AXI AP transaction error, DAP status 30000021
I am currently having problems loading the helloworld build on SDK to the the ARM.  I used prebuilt hdf file provided by xilinx to create the bsp, fsbl, and the helloworld app. (attached are the project files).  On the hardware, I set all the switches on SW6 to the “ON” position so the system will boot on JTAG, and I connected a USB to microUSB to the to J83 on the board.  My debug configurations are as follows (See debugConfigs.png).
I get the following error when running the debugger (error.png).
Below is the output of the sdk log:
My SDK Log:
11:24:14 INFO : Connected to target on host '127.0.0.1' and port '3121'.
11:24:15 INFO : Jtag cable 'Xilinx HW-Z1-ZCU111 FT4232H 93153A' is selected.
11:24:15 INFO : 'jtag frequency' command is executed.
11:24:15 INFO : Sourcing of 'C:/Xilinx/SDK/2018.3/scripts/sdk/util/zynqmp_utils.tcl' is done.
11:24:15 INFO : Context for 'APU' is selected.
11:24:16 INFO : System reset is completed.
11:24:19 INFO : 'after 3000' command is executed.
11:24:19 INFO : Context for 'APU' is selected.
11:24:20 INFO : Cleared APU and A53 resets
11:24:20 INFO : Context for 'RPU' is selected.
11:24:20 INFO : Cleared RPU and R5 resets
11:24:20 INFO : Split mode is enabled for R5#1
11:24:20 INFO : 'targets -set -filter {jtag_cable_name =~ "Xilinx HW-Z1-ZCU111 FT4232H 93153A" && level==0} -index 0' command is executed.
11:24:40 INFO : FPGA configured successfully with bitstream "C:/Users/leee1/workspace/rfsoc_hw/zcu111_rfsoc_trd_wrapper.bit"
11:24:40 INFO : Context for 'APU' is selected.
11:24:41 INFO : Hardware design information is loaded from 'C:/Users/leee1/workspace/rfsoc_hw/system.hdf'.
11:24:41 INFO : 'configparams force-mem-access 1' command is executed.
11:24:41 INFO : Context for 'APU' is selected.
11:24:41 INFO : Sourcing of 'C:/Users/leee1/workspace/rfsoc_hw/psu_init.tcl' is done.
11:24:44 INFO : 'psu_init' command is executed.
11:24:44 INFO : Sourcing of 'C:/Xilinx/SDK/2018.3/scripts/sdk/util/fsbl.tcl' is done.
11:24:45 INFO : 'after 1000' command is executed.
11:24:45 INFO : 'psu_ps_pl_isolation_removal' command is executed.
11:24:46 INFO : 'after 1000' command is executed.
11:24:47 INFO : 'psu_ps_pl_reset_config' command is executed.
11:24:47 INFO : 'catch {psu_protection}' command is executed.
11:24:47 INFO : Context for processor 'psu_cortexr5_0' is selected.
11:24:47 ERROR       : AXI AP transaction error, DAP status 30000021
11:24:47 INFO : ----------------XSDB Script----------------
connect -url tcp:127.0.0.1:3121
source C:/Xilinx/SDK/2018.3/scripts/sdk/util/zynqmp_utils.tcl
targets -set -nocase -filter {name =~"APU*" && jtag_cable_name =~ "Xilinx HW-Z1-ZCU111 FT4232H 93153A"} -index 1
rst -system
after 3000
reset_apu
targets -set -nocase -filter {name =~"RPU*" && jtag_cable_name =~ "Xilinx HW-Z1-ZCU111 FT4232H 93153A"} -index 1
clear_rpu_reset
enable_split_mode
fpga -file C:/Users/leee1/workspace/rfsoc_hw/zcu111_rfsoc_trd_wrapper.bit
loadhw -hw C:/Users/leee1/workspace/rfsoc_hw/system.hdf -mem-ranges [list {0x80000000 0xbfffffff} {0x400000000 0x5ffffffff} {0x1000000000 0x7fffffffff}]
source C:/Users/leee1/workspace/rfsoc_hw/psu_init.tcl
psu_init
source C:/Xilinx/SDK/2018.3/scripts/sdk/util/fsbl.tcl
after 1000
after 1000
targets -set -nocase -filter {name =~"*R5*0" && jtag_cable_name =~ "Xilinx HW-Z1-ZCU111 FT4232H 93153A"} -index 1
rst -processor
----------------End of Script----------------
I haven't found a lot of resources on booting a baremetal application on the ZCU111 via JTAG using the SDK.  Is this function deprecated?
Edwin
Re: ZCU111 Eval Board: Loading Bare Metal on Arm R5: AXI AP transaction error, DAP status 30000021
Your FSBL needs to be built targeting the R5(Instructions to do this are provided in UG1209).   Then you select the R5 as a target, reset it, and dow that FSBL.   I used this tcl script to boot the FSBL on the R5
connect
#tcl to load FSBL instead of psu_init
#load FPGA
#fpga -f zcu111.bit
#Disable Security gates to view PMU MB target
targets -set -filter {name =~ "PSU"}
#By default, JTAGsecurity gates are enabled
#This disables security gates for DAP, PLTAP and PMU.
mwr 0xffca0038 0x1ff
after 500
#Reset R5, load and run FSBL
targets -set -filter {name =~ "Cortex-R5 #0"}
rst -processor
dow fsbl_r5/debug/fsbl_r5.elf
con
#Give FSBL time to run
after 5000
stop
Here is a wiki page describing one method to boot over JTAG.   Can you provide your hdf and I'll try it here.
Visitor werr4ever
The hdf file is the prebuilt 2018.3 for the SSRIPDesign_1x1, but here is the attached hdf file
Visitor werr4ever
glena,
I was also more concern with debugging my app on the SDK than just starting the application with a tcl script on the ZCU111.  Is that option not possible?  I guess if the tcl script work, I could always attach the debugger to the process...  but that would be annoying.  Is there a option in the sdk to run that script while doing debugging on the Eclipse IDE?
Yes there is.      To load the bitstream / fsbl / pmufw on your board, use a script.  You can find a good example in UG1137 in the section "Loading PMU Firmware in JTAG Boot mode".   Just end the script after the FSBL is loaded.
From there you can debug your applications in SDK -- just make CERTAIN that 'Run psu_init' is not selected in Debug Configurations.
Visitor werr4ever
Apparently, running the instructions you gave me earlier gave me a compile error saying it is missing a file...
"Running Make libs in psu_pmu_0/libsrc/rfdc_v5_0/src"
"Compiling rfdc"
In file included from xrfdc.c:138:0:
xrfdc.h:213:10: fatal error: metal/sys.h: No such file or directory
#include <metal/sys.h>
compilation terminated.
In file included from xrfdc_g.c:37:0:
In file included from xrfdc_intr.c:56:0:
In file included from xrfdc_mixer.c:49:0:
In file included from xrfdc_mts.h:66:0,
from xrfdc_mts.c:59:
In file included from xrfdc_sinit.c:58:0:
That error indicates that you need to add in the libmetal directory to the bsp.    Something to keep in mind, the TRD isn't really meant to be edited - it's targeted to be more of a demonstration of capabilities.
For something to edit and add in your own secret sauce, I'd suggest working from the analyzer design in the lounge
Visitor werr4ever
Hi glena,
Yeh I realized that the TRD design doesn't have a Microblaze, hence I couldn't run the tcl script you linked me to.  Is there a specific build I can run on and be successful at running the following instructions for, https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/66551810/Creating+FSBL+PMUFW+from+XSCT+for+ZCU111+and+boot+over+JTAG?
Any hdf for a ZCU111 should work with that wiki script.   I used the script I sent to you on the hdf from the TRD with no issues after adding the libmetal library to the BSPs.
Visitor werr4ever
I am still having trouble with the tcl script...  I am using the prebuilt trd hdf file, maybe there is an updated one I am not aware of.  Is there a way you can send me that hdf file?
Anyway, I ran the script line by line and in board_bringup the "targets -set -nocase -filter {name =~ "PSU"}" didn't find a target after connect (See attached).  Do you having a different hardware setup than mine?  I am using the USB to JTAG port, with SW6 all "ON".  Are the names different in my device?  Does "PSU" in the script corresponds to PS TAP, and "Microblaze PMU" corresponds to PMU.
Edwin
Try this wiki page, I ran this earlier today and it worked well for me (download and extract the .zip, in xsct 'source xsct_script.tcl' then run 'board_bringup design_1_wrapper.hdf'.    Note that in  'proc board_bringup' you need to change 'dow fsbl' to 'dow zynqmp_fsbl/executable.elf'.
Visitor werr4ever
I ran the script and the exact same thing happen.
The line "targets -set -nocase -filter {name =~ "PSU"}" outputs "no targets found with "name =~ "PSU".  This means I have no targets with the name "PSU".  I get the following targets:
1 PS TAP
2 PMU
3 PL
4 dummy_dap
5 xc7vx690t
6 Legacy Debug Hub
None of this has the name "PSU" on it, hence we cannot write anything on it.  This is with your hdf file as well.  Could you check if your targets are the same as mine with the following command?  If not, there is definitely something different with our configurations or how we are hooking up our ZCU111.
Are you sure you are booting in JTAG boot mode?
Visitor werr4ever
We do have a cable going to the USB JTAG and all the SW6 is ON.  From the documentation I have read, that means it should be booting on JTAG boot mode.  Unless there are other instructions I don't know about.  Is something not connected right (see attached)?  Are there instructions to ensure I am actually booting from JTAG?
Is this a new board?   By that, I mean has it ever worked for you?   Your JTAG chain shows an XC7V device, that device is not used on the ZCU111, is it on an FMC board?
Seeing the 'dummy_dap' makes me think you are booting in QSPI boot mode with no valid image in QSPI.   The screen you showed describes the launching of hw_server which is used by the host to communicate with the target, it provides no information about the target.
Yes, all switches on SW 6 set to on is JTAG boot mode.  Anytime the boot mode is changed, the board needs to be power cycled (go through a POR cycle so the BootROM can query the boot mode settings).
Your JTAG chain should look like this when booted from JTAG mode.zcu111_targets.JPG
Visitor werr4ever
Hi glena,
It finally worked.  However, is there a way to run a application on the Arm R5_0 instead of the Cortex-A53.
In the A53-0 the reset commands and loading the fsbl are the following.  I know inorder to download the fsbl to the R5, I will need to change "Cortex-A53 #0, to Cortex-R5 #0 on the script.  But what memory do I write to release the R5-0 reset and the bootloop.  Below are the lines to do it for the A53-0.
# write bootloop and release A53-0 reset
mwr 0xffff0000 0x14000000
mwr 0xFD1A0104 0x380E
# Download FSBL to A53 #0
targets -set -filter {name =~ "Cortex-A53 #0"}
connect
#load FPGA
#fpga -f zcu111.bit
after 500
rst -processor
con
after 5000
stop
