ZYNQ ARM debug
what kind of hw should be used in order to debug ARM sw on ZYNQ exploiting SDK? Is it possible to use xilinx usb platform cable II? Actually i'm not using an evaluation board. The configuration of boot is "independent JTAG mode".
Thank you for your attention.
Re: ZYNQ ARM debug
Hi @alessandro_0110
Yes you can use Xilinx Platform Cable II, Xilinx Smartlynq Cable or the digilent cables/modules like we use in our evaluation boards.
Ibai
