ZYNQ7035, only scan core#0 in SDK,can not scan another core!
    We designed a board used XC7Z035-2FFG676I, but when we create a PS test program, found that only one core(core #0) scanned by SDK, and the development environment is VIVADO2016.4.
    The PS test Projrect show below:
    But we have a Development board as same as used XC7Z035-2FFG676I, On that board,when PS test program download to board, there are Dual-ARMCore in SDK, See below:
    I want to know what reasons can casue this problem! Thank you very much.
    The Process below is my PS test projrect creating steps:
Hi @angenia
Are you sure that the device mounted in your board is not a Zynq-7000S family device? I mean, those devices are just single core instead of dual.
Ibai
Ibai
