raffa1993
Zynq 7000 SD card boot image issue
Dear All,
My name is Raffaele, I'm an Embedded Engineer.
I've been working for a couple of months with the Zynq 7000, using a custom board: while debugging with JTAG or booting via QSPI both work perfectly, but I still cannot boot through the SD Card.
Now I've created a simple workspace with a Hardware Platform Specification, a Board Support Package, an FSBL and an application that simply print out on the Serial Port an "hello world" message: I've successfully run it with JTAG and I've also created a bootable image inside the QSPI.
When I create the "boot.bin" file for the SD Card and I try to boot via SD Card, nothing happens.
The hardware around SD boot has been properly verified with a "boot.bin" sample, so I suppose that the problem could be in the configuration of the boot image.
Can anybody help me?
Thanks in advance,
Raffaele
timothyv
Hello @raffa1993
To start, I would like to point you to a previous Answer Record that deals with Zynq 7000 SD Programming/Booting Cecklist. I believe this may help in trying to debug. I have also attached a forum question that is very close to what you are trying to do.
I hope this helps!
AR: https://www.xilinx.com/support/answers/59476.html
Forum: https://forums.xilinx.com/t5/Other-FPGA-Architecture/How-to-make-bootable-SD-card-for-Zynq-7000-series-PL-only/td-p/876083
