kvanegmond
Zynq-7000 in XIP mode
I want to boot a Zynq-7000 with bitstream and a small application using XIP.
I've created a bif file which looks like this:
//arch = zynq; split = false; format = MCS
the_ROM_image:
 [bootloader,xip_mode]D:\DESIGNS\Vivado20182\Zynq_NoDDR\WS_ddr\FSBL\Debug\FSBL.elf
 D:\DESIGNS\Vivado20182\Zynq_NoDDR\WS_ddr\System_wrapper_hw_platform_0\System_wrapper.bit
 D:\DESIGNS\Vivado20182\Zynq_NoDDR\WS_ddr\blinkleds\Debug\blinkleds.elf
In bootgen I read in this file and write a new bif file and msc.
The bif file now looks like this:
the_ROM_image:
 [bootloader]D:\DESIGNS\Vivado20182\Zynq_NoDDR\WS_ddr\FSBL\Debug\FSBL.elf
xip_mode is no longer visible, so I'm doubt if the MCS realy contains an image that will boot in XIP mode.
Can somebody elaborate on this?
Kees van Egmond
FAE 4 Xilinx @ Avnet Silica Netherlands
smarell
Community Manager
Community Manager
No. It's not set. Can you please generate the MCS using bootgen command in command line?
smarell
Community Manager
Community Manager
