muh_ali
Zynq MIO Conf. Reset Signals in EDK 14.7
Reset signals for ethernet and usb peripherals on EDK 14.7 are not selectable. Please look at the attached screenshot. By the way, this core is created in PlanAhead project.
How can we select the reset signals?
Ali
muh_ali
I thought about force the reset signals on MIO port, then I enabled GPIO port. And after that reset signals became selectable.
Ali
muh_ali
Ali
