Visitor sosod
Zynq: SCU
I have questions about the scu on zynq.
1. About the SCU_Control_Register (0xF8F00000)
I have read the Zynq TRM and the ARM Cortex A9 MPCore TRM documentations. But those two documents don't say the same thing about enabling the SCU and the value of the first bit of the register
In the Zynq TRM, it is said that the first bit is at 0 by default and that SCU is disable. To enable SCU, this bit must be 1.
In the ARM Cortex A9 MPCore TRM, it is the opposit: the first bit is at 1 by default and that SCU is disable. To enable SCU, this bit must be 0.
Which one should I trust ?
2. I have read that SCU is responsible for cache coherency and interconnect arbitration. What happens if I disable the SCU? How is the arbitration done and will the address filtering still working?
Re: Zynq: SCU
There is no difference. I hope you are checking bit SCU_enable
In Zynq TRM:
SCU_enable 0 rw 0x0
1 = SCU enable.
0 = SCU disable. This is the default setting
In ARM TRM:
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0407g/DDI0407G_cortex_a9_mpcore_r3p0_trm.pdf (Page 2-5)
[0] SCU enable
1 = SCU enable.
0 = SCU disable. This is the default setting.
The SCU block connects the two Cortex-A9 processors to the memory subsystem and contains the
intelligence to manage the data cache coherency between the two processors and the L2 cache. This
block is responsible for managing the interconnect arbitration, communication, cache and system
memory transfers, and cache coherence for the Cortex-A9 processors.
Debraj
Re: Zynq: SCU
In Zynq TRM:
SCU_enable 0 rw 0x0
1 = SCU enable.
In ARM TRM:
[0] SCU enable
1 = SCU enable.
Debraj
Visitor sosod
Re: Zynq: SCU
Thank you for your reply.
It seems ARM has changed his manual since the Zynq exists. And I was looking at the release r4p1 in which it is different. I will follow what the Zynq TRM says.
