deniss
Zynq UartPs_1 interrupt issue
I have an application that uses UartPs_1 from Zynq in interrupt mode. I have problem with the interrupt on receive side, as follows.
I have to receive multiple messages with different lengths. These messages don't have a terminator. They are separated only by an idle condition (minimum 11 bits of "1").
To take into account this idle condition, I used the receiver timeout mechanism from Zynq. I'm not sure if it is OK.
Also, after the interrupt announces that all the data has been received
 successfully, I don't find a way to read the received data.
If I read byte with byte, it's working but I don't know where to stop reading for a certain received message (they can have different length in bytes). If I try to read the entire buffer, then the interrupt handler stops working.
I'm using the uartps_v3_6 driver and I used the examples provided for it, like "xuartps_intr_example".
Any suggestion might help me a lot.
Thank you in advance.
