Zynq UltraScale+ Processing System DDR Burst Length
I get an error when trying to attach the SDK to the target via JTAG. The error is the same as detialed in this Answers Record:
https://www.xilinx.com/support/answers/67623.html
The solution is to use the "Zynq UltraScale+ Processing System GUI" to modify the "PS DDR Burst Length" to be 8 instead of the default of 16. I'm using Vivado 2018.3 and VCU TRD design (rdf0428) on the ZCU106 dev board and I have not been able to find any option to change the DDR burst length.
How can the burst length be changed?
Running FSBL first then my app fixed the problem.
That setting is removed in the latest version.
Please check the following SODIMM issue for your ZCU106 board. I think you would need to run FSBL first, then run VCU TRD example.
https://www.xilinx.com/support/answers/71961.html
