limegreen987
Zynq Vivado 2014.2 Xilinx SDK 2014.2 - xspi_polled_example Not Completely Working
When I step through the SpiPolledExample in debug mode, I can successfully exit this function.
When I try to step over SpiPolledExample in debug mode, the program gets stuck in the XSpi_Transfer function.
while(ByteCount > 0) {
			 * Wait for the transfer to be done by polling the
			 * Transmit empty status bit
			do {
				StatusReg = XSpi_GetStatusReg(InstancePtr);
			} while ((StatusReg & XSP_SR_TX_EMPTY_MASK) == 0);
			 * A transmit has just completed. Process received data
			 * and check for more data to transmit. Always inhibit
			 * the transmitter while the transmit register/FIFO is
			 * being filled, or make sure it is stopped if we're
			 * done.
			ControlReg = XSpi_GetControlReg(InstancePtr);
			XSpi_SetControlReg(InstancePtr, ControlReg |
						XSP_CR_TRANS_INHIBIT_MASK);
			 * First get the data received as a result of the
			 * transmit that just completed. We get all the data
			 * available by reading the status register to determine
			 * when the Receive register/FIFO is empty. Always get
			 * the received data, but only fill the receive
			 * buffer if it points to something (the upper layer
			 * software may not care to receive data).
			while ((StatusReg & XSP_SR_RX_EMPTY_MASK) == 0) {
				Data = XSpi_ReadReg(InstancePtr->BaseAddr,
								XSP_DRR_OFFSET);
				if (DataWidth == XSP_DATAWIDTH_BYTE) {
					 * Data Transfer Width is Byte (8 bit).
					if(InstancePtr->RecvBufferPtr != NULL) {
						*InstancePtr->RecvBufferPtr++ =
							(u8)Data;
				} else if (DataWidth ==
						XSP_DATAWIDTH_HALF_WORD) {
					 * Data Transfer Width is Half Word
					 * (16 bit).
					if (InstancePtr->RecvBufferPtr != NULL){
					    *(u16 *)InstancePtr->RecvBufferPtr =
							(u16)Data;
						InstancePtr->RecvBufferPtr += 2;
				} else if (DataWidth == XSP_DATAWIDTH_WORD) {
					 * Data Transfer Width is Word (32 bit).
					    *(u32 *)InstancePtr->RecvBufferPtr =
							Data;
						InstancePtr->RecvBufferPtr += 4;
				InstancePtr->Stats.BytesTransferred +=
						(DataWidth >> 3);
				ByteCount -= (DataWidth >> 3);
			if (InstancePtr->RemainingBytes > 0) {
				 * Fill the DTR/FIFO with as many bytes as it
				 * will take (or as many as we have to send).
				 * We use the Tx full status bit to know if the
				 * device can take more data.
				 * By doing this, the driver does not need to
				 * know the size of the FIFO or that there even
				 * is a FIFO.
				 * The downside is that the status must be read
				 * each loop iteration.
				while(((StatusReg & XSP_SR_TX_FULL_MASK)== 0) &&
					(InstancePtr->RemainingBytes > 0)) {
						 * (8 bit).
						Data = *InstancePtr->
								SendBufferPtr;
						 * Word (16 bit).
						Data = *(u16 *)InstancePtr->
								SendBufferPtr;
						 * (32 bit).
						Data = *(u32 *)InstancePtr->
								SendBufferPtr;
					XSpi_WriteReg(InstancePtr->BaseAddr,
							XSP_DTR_OFFSET, Data);
					InstancePtr->SendBufferPtr +=
							(DataWidth >> 3);
					InstancePtr->RemainingBytes -=
							(DataWidth >> 3);
							InstancePtr);
				 * Start the transfer by not inhibiting the
				 * transmitter any longer.
				ControlReg &= ~XSP_CR_TRANS_INHIBIT_MASK;
				XSpi_SetControlReg(InstancePtr, ControlReg);
Where...
- ByteCount = 1
- StatusReg & XSP_SR_RX_EMPTY_MASK = 1
- InstancePtr->RemainingBytes = 0
Does my error reside in Vivado?
Thanks!
ibaie
Hi @limegreen987,
Are you still facing the issue? On which statement is looping your execution? I mean from your output seems that it already send the byte and RX_Empty is already set so not sure on which loop is your execution blocked.
Ibai
Ibai
limegreen987
Hello @ibaie,
I am still running into this issue.
I am stuck in "while(ByteCount > 0)".
- ByteCount = 1
I cannot update ByteCount because I cannot enter the while loop "while ((StatusReg & XSP_SR_RX_EMPTY_MASK) == 0)".
Thank you for reaching out.
