Zynq and SDHC card
 I want to use an SDXC/SDHC memory card on an zynq in a bare-metal application.
(my card would be pre formated, and i read the flash to know where i write my data)
I would like to know if I can find a low level C libraries that initalize the card in high speed mode and acces to the SD card memory .
i do not want to write the hole driver.
thanks,
tom
I'm looking for similar information.  I've also posted in the zedboard.org forums:
http://www.zedboard.org/content/sd-card-example-design-using-standalone
Hi Guys,
I'm writing a small RTOS based on FreeRTOS for Zynq, and I am also having the same problem... there simply is not much information on SDHCI. The simplified specs are basically useless unless you already know a lot about SDCards.
The nice thing is that the controller conforms to SDHCI standard, and so there are a few open-source drivers that implement basic sdcard access. E.g. raspberry pi....
Checkout -- https://github.com/jameswalmsley/rpi-boot/blob/master/emmc.c (I forked it on github and using to help me write a fully featured driver).
If you're interested in a fully featured driver, checkout http://github.com/jameswalmsley/bitthunder/ in 2/3 weeks from now.
You need to look under driver/mmc/host/sdhci.c
It seems there's no support from Xilinx for doing this either, they basically expect you to use their FSBL, which is pretty slow at SDcard access, or linux.
Hope this helps,
James
