about pull up a pin in XPS
hi,thank you for your attention.
i'm doing an IP block in Verilog ,while i pull up a pin in ISE verilog project , it works (add a pull up statement in UCF file), but then i make my own IP block with using the XPS Create or import peripheral function , turn out this pin does not really pull up, it pull high!!!!  i did NOT make any change !!!!
 found some information about using wrapper to pull pin up in EDK , but i don't understand how , anyone can share more details?
Re: about pull up a pin in XPS
I don't understand the difference between "pull up" and "pull high".
I would still use the UCF to apply an internal pull up to a pin. Just make sure that the pin in question is specified only in one UCF.
Howard
"That which we must learn to do, we learn by doing." - Aristotle
