yulei
arm-none-eabi-gcc
hi all:
how can i find "command syntax guide" about arm-none-eabi-gcc.
aravindb
Hi @yulei
You can just run arm-none-eabi-gcc --help
It will display usage options.
Thanks & Regards
Aravind
yulei
is there some docs, provided by xilinx
rfeneon
you can get the documentation directly at the gnu site:
https://gcc.gnu.org/onlinedocs/gcc-7.2.0/gcc/
