woodring
axi_interconnect 1.06 no vhdl model?
I'm trying to do a Modelsim behavioural simulation of the xapp1026 files.  I only have a vhdl enabled simulator Modelsim 10.2.
The EDK is set for vhdl simulation not verilog.
When I generated the HDL simulation files and then try to run the simulation, I get an error that I don't have a verilog enabled license for Modelsim.  I also note that in the created system.do script that compiles the simulation files, the only component using verilog (vlog command vs. vcom) is the axi_interconnect component.
When I look at : \14.6\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_interconnect_v1_06_a\hdl there is only a verilog subdirectory for the interconnect core?   Why no vhdl?  Other components have the vhdl file?
Thanks for any replies.
cwood
bwiec
The core is only provided as Verilog. If you really need VHDL, you could synthesize the core, use netgen, and back-annotate your simulation with the resulting VHDL simulation model (in lieu of the Verilog source).
www.xilinx.com
woodring
Thanks for the reply.   I will look into this and post back if I got the simulation running.
