noel.aye
bitbake recipe modification for fsbl build
When I build fsbl, I've got "warning: "XPS_BOARD_ZCU102" redefined"; I wanted to clear this warning.
When I looked around the source tree, I have found the following recipe file containing this variable:
xilinx-zcu102-zu9-es2-rev1.0-2017.2/project-spec/meta-user/recipes-bsp/fsbl/fsbl_%.bbappend
that has the following:
YAML_COMPILER_FLAGS_append = " -DXPS_BOARD_ZCU102"
After removing this line, I've recompiled but the above warning did not disappear either.
So, I've searched in the PetaLinux toolchain (v2017.2.1) and I have found the following file:
Petalinux/components/yocto/source/aarch64/layers/meta-xilinx-tools/recipes-bsp/fsbl/fsbl_git.bb
and inside was
YAML_COMPILER_FLAGS_append_zcu102-zynqmp = " -DXPS_BOARD_ZCU102"
and commented it out again. But, the warning still did not disappear.
My questions now are:
is this the right approach for my objective, i.e. to clear the warning?
am I missing some other recipe files to modify?
shabbirk
This is not the right place to modify the changes:-
You could try something like this to remove this support (Try adding local.conf)
YAML_COMPILER_FLAGS_remove = " -DXPS_BOARD_ZCU102"
 Best Regards
Shabbir
vineethc
It is always good to use project-spec/meta-user/conf/petalinuxbsp.conf instead of local.conf
noel.aye
I have tried the suggestion but it did not remove the flag unfortunately.
Moreover, the ideal solution should be localized to the fsbl building only. If we apply at the local.conf, doesn't it affect the whole system?
vineethc
in the meta-user fsbl bbappend try this
replace append with remove
noel.aye
Thanks for all the responses -- one way or another they have enlightened me in different perspective into the yocto system of the petalinux.
So far I've managed to solved this problem just by removing the line
from
But, this step alone is not sufficient for my case.
I need to to do the following two clean-up steps before my change (i.e. removal of XPS_BOARD_ZCU102) taking effect:
$ petalinux-build -x mrproper
$ rm -rf <plnx-proj-root>/components/plnx_workspace
The result was verified from  "build/tmp/work/plnx_aarch64-xilinx-linux/fsbl/2017.2+gitAUTOINC+122565ec40-r0/temp/log.do_compile".
