kbj1213
block automation in Block Design (Zynq)
Hi, I'm beginner for SoC on FPGA.
My FPGA Board is zcu102.
I'm practicing to configure PS & PL on FPGA board using Vivado & Vitis 2021.01 version.
I'm following "ug1209-embedded-design-tutorial".
On 17 page of the user-guide, there is "Run Block Automation".
After operating "Run Block Automation", it seems that the zynq_ultra_ps module get I2C, UART, USB, GPIO etc by default.
But in my vivado program, there is no "Run Block Automation" button (Green bar).
 As I know, "Run Automation Block" could be done also by tcl command "apply_bd_automation -rule xilinx.com:bd_rule:zynq_ultra_ps_e -config {apply_board_preset "1"} [get_bd_cells zynq_ultra_ps_e_0]"
but after I do the tcl command, nothing happens.
Is there any reason for that?
yzhang
Did you set zcu102 board in vivado project setting?
yzhang
kbj1213
That was my fault. Thank you very much !
