bmassey
bootgen Issue with ZYNQMP using Rolling Key Encryption, the PMU is reported to be larger than allowable
I'm using ZynqMP (on the zcu104 board)   part = xczu7eg
When I setup my 'BIF' file to use rolling key encryption with the rolling key block size set to anything less than 8192 I get the following error during bootgen:
[ERROR] : Total PMU Firmware size 158KB > maximum allowable size (128KB)
If I change the block size to 8192, ie. blocks=8192(*) , bootgen works but the resultant BOOT.BIN file does not boot.
If I disable rolling key for the FSBL (Just do normal encryption on the FSBL), but all the other partitions are encrypted with rolling key... it works.
I've attached the working BIF file I spoke of.. I've also attached the nonWorking.bif ... the only difference between the two is the blocks= setting on the FSBL PARTITION
Any help would be appreciated.
-Bud Massey
rdarapun
Hi @bmassey
Your understanding of increase in size with key rolling is correct. But, decryption is of fsbl/pmufw image is NOT done directly while reading from the flash.
The complete encrypted FSBL is copied into OCM, and then decrypted. This is applicable to pmufw image as well.
So, increase in encrypted FSBL size beyond available OCM(250KB) doesn't work.
Similarly, incearse in encypted pmufw size beyond available PMU RAM(128KB) also doesn't work.
Can you please try key rolling on FSBL/PMUFW, so that the encrypted size is not beyond the above mentioned?
pmallad
Hi Bud Massey,
When you enable key rolling, there is an overhead added to the encrypted image. If there are n blocks created during key rolling, the overhead added will be (64 + n * 64)  bytes. The error you were seeing with <8192 bytes for block, was because of the size of PMU FW getting increased because of this overhead and was going out of limit expected for PMU FW.
When blocks=8192(*) is specified, the issue with PMU FW is not there anymore, as the size of the PMU FW with the overhead could have been less than the expected size. But the reason for not booting properly could be because of overall size of PMU FW + FSBL + total encryption overhead crossing the actual OCM size.
Can you try increasing the block size more and give it a try?
bmassey
I understand that when you use rolling key it increases the size of the encrypted image in flash (that makes sense).  So the FSBL and PMU images stored in flash are larger.  During boot the encrypted images are read out of flash and decrypted and written to memory (OCM).  Once unencrypted the PMU and FSBL sizes are fine and fit into memory.  So I don't see why rolling key should not work regardless of block size.
Block size of 8192 worked with bootgen (I didn't get the PMU oversize error), but the resulting BOOT.bin file did not boot.
Thanks for the reply.
rdarapun
Hi @bmassey
bmassey
Hi@rdarapun   Sorry for the slow response.  I was out of the office.  I've tried your suggestion.
I tried rolling key on the FSBL/PMU for the following.
Block Size        Issue
  • 256                 Bootgen error PMU too large
  • 1024               Bootgen error PMU too large
  • 8K                  Bootgen worked but resulting BOOT.bin did not boot properly
  • 16K                Bootgen worked and device boots properly
I'll go with 16K block size for the FSBL.
Note:  There is only a problem if you are including a PMU partition.
Thanks for the response.
