build Petalinux system image
Hello all,
I'm building a system image of petalinux but it doesn't work...
There are two errors,  does anybody know how to solve it?
ERROR: fsbl-0.2+xilinx+gitAUTOINC+ef07b552f4-r0 do_configure: Function failed: do_configure (log file is located at /home/zzh4hi/petalinux_zhe/xilinx-zcu102-2016.4/build/tmp/work/aarch64-xilinx-linux/fsbl/0.2+xilinx+gitAUTOINC+ef07b552f4-r0/temp/log.do_configure.20122)
ERROR: Logfile of failure stored in: /home/zzh4hi/petalinux_zhe/xilinx-zcu102-2016.4/build/tmp/work/aarch64-xilinx-linux/fsbl/0.2+xilinx+gitAUTOINC+ef07b552f4-r0/temp/log.do_configure.20122
Thanks a lot
Holzmann
Re: build Petalinux system image
Can you pass on the log file mentioned in the error message?
Do you see the same if you use
petalinux-build -c bootloader
