cache problems with ZYNQ AMP
HI:
    I am using ZYNQ in AMP mode:   CPU0 runs Linux and CPU1 runs a bare-metal application
    CPU0 and CPU1 communicates with each other through the shared memory.
   The bare-metal application shutdown the L2 cache  and  config the shared memory cached.
   Then I use the following function to access the physical address in linux
   memfd = open("/dev/mem", O_RDWR | O_SYNC);
   mmap(0, 0x10000, PROT_READ | PROT_WRITE, MAP_SHARED, memfd, dev_base & ~ddr_mask);
  My questions are as follows
 1: Is the mmaped memroy in linux  cached or non-cached ?  I think It's non-cached
 2: when the CPU1 configs the shared memory cached ,the mmaped access to the memory in linux may have a cache
 inconsistent .But when the CPU1 configs the shared memory non-cached ,it takes about 3 times longer to run the program.
  Is there any better solutions to this questions? Thanks very much!
Good ;-)
Cache disabled.
> in linux may have a cache inconsistent
There should be no coherency issues due to CPU0 since shared memory should be cache disabled. However, if cache is enabled for the CPU1 shared memory region: you have to flush (after CPU1 writes data) and invalidate (before CPU1 reads data).
Good ;-)
Cache disabled.
