Newbie rajesh93
calculation of RGB intensities of an image
can any one suggest me  a vhdl code for calculating RGB intensities of each pixel of an image?
Re: calculation of RGB intensities of an image
although your question is missing a bit of detail I assume that you are looking for the gray scale equivalent of a RGB pixel.
Please review this IP, you can use the Y value as seen on page 15.
http://www.xilinx.com/support/documentation/ip_documentation/v_rgb2ycrcb/v4_0/pg013_v_rgb2ycrcb.pdf
Are you trying to do some image processing on the input image? You can check out the image statistics IP which should be something which should help your case - http://www.xilinx.com/support/documentation/ip_documentation/v_stats/v5_00_a/pg008_v_stats.pdf
It gives a y channel histogram of the input image.
Anirudh
