can ONLY Run program on SDK for one time?
   I create an example project(hello world) on SDK, and run on my Kintex7 evaluation board. For the first run, the console receive "hello world", then I run again, and got the warning the "processor is currently in use", so I type "stop" on XMD console to stop the processor, then I run the program, but I unrecognized code on console.    I have tried many times, but got the same result.
Could someone help me? Thanks.
Since this is a Kintex-7 evaluation board(I am assuming KC705), would that be possible to share the workspace?
--Hem
Are you trying to Run the application or Debug the application?
Can you check the below link and see which process are you following ?
http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_3/SDK_Doc/tasks/sdk_t_run_main.htm
Looking at the details , you are trying to run the application .Try to use option "application to run".
Achutha
Once you click on stop, can you try to do a rst in XMD and relaunch the application again?
--Hem
Hi achutha:
I want to Run the application. The problem is that for the first time of running, I could got "hello world" in console, but when I re-run, I can only get unrecognized code even I type "stop" or "rst" in XMD.
Does it really means that if the program is running on Microblaze, we need to reset the processor so that we could re-run the program?
Hi htsvn:
If I click "Debug as" > "launch on hardware(GDB)", then I could get "hello world" for the first run. Yes, I could reset the system by "rst" in XMD, but if I re-run the program, I could only get unrecognized code. And I do "rst" then re-run for several times, only get same unrecognized code.
bowen_fu Which version of SDK are you using?
I am using: Release Version: Release 14.6 Build SDK_P.68d
--Hem
Thanks for your help, I figure out that if I Debug as > launch on hardware, and right click the relaunch to re-run, then it will be good.
This is a reply to an extremely old thread. In my case, I have two applications: So I run the first, is successful.
Then I run the second one, this is also successful.
When I run the first again now, nothing shows up on SDK.
The problem in my case was that I was missing cleanup_platform()  at the end of the second program, which was probably why the first one didn't run after the second was executed.
After I added the line, both applications run fine one after the other.
Dimple
