can not unzip ug1209 design_files
I tried to following the download link from UG1209, which leads to:
https://www.xilinx.com/cgi-bin/docs/ctdoc?cid=54fdb4d3-f267-4986-ae73-1c66c2c100f2;d=ug1209-embedded-design-tutorial.zip
The zip file downloaded can not be unzipped. Can you please take a look? Thanks.
Yong
Re: can not unzip ug1209 design_files
HI @yongxiao
Windows seems to have issues opening it but if I use a tool like 7-zip, it opens it but it still seems to be corrupted.
What version are you targetting? If 2019.1 you can use the following link:
https://www.xilinx.com/member/forms/download/design-license.html?cid=0735a818-7dc5-4181-8484-a6901fb33ce3&filename=ug1209-embedded-design-tutorial.zip
this is the link you can get from docnav when opening the document:
Thanks, I am using 2018.03  from ubuntu linix
The link for 2018.3 seems to be the same as for 2019.1:
