05-11-2015 12:22 PM
I've install SDK 2014.14 (SDK only) from web site. It does not require any license as far as I understand.
But on trying to create BSP I face some difficulties:
1. BSP standalone, can be created and I see on failures.
2. But on trying to create BSP based on xilkernel I get error:
[Hsi 55-1442] Error(s) while running TCL procedure generate() 22:17:48 ERROR : Error generating bsp sources: Failed to generate BSP. 22:17:48 ERROR : Failed to generate sources for BSP project xilkernel_bsp_0hhh org.eclipse.core.runtime.CoreException: Internal error occurred while generating bsp sources. Please check the SDK Log view for further details. at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.internalGenerateBsp(RegenBspSourcesHandler.java:178) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.access$2(RegenBspSourcesHandler.java:163) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1$1.run(RegenBspSourcesHandler.java:131) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1.run(RegenBspSourcesHandler.java:135) at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Please Advise,
Ran
05-11-2015 01:20 PM
05-11-2015 05:24 PM
hi,
there are a few basic peripherals needed to make a XIlkernel BSP such as a timer and interrupt controller.
If you are trying to build a xilkernel bsp with microblaze, refer to ug758 http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/ug758.pdf
--hem
05-11-2015 10:07 PM
Thanks for the suggestions.
I am trying to build xilkernel BSP project. On the create process there are failures (I didn't try yet to build). There is no such problem on creating standalone BSP project.
It might be related to missing peripherals such as timer , and interrupt controller, as Hem said.
I will check this and get back with results.
Thank you very much,
Ran
