mkjaswal
cannot see output of code/ step through in XMD in SDK nor in hyperterminal
Commands used:
1) connect mdm
says- "Connected to MDM UART Target
XMD% JTAG-based Terminal Server.
(TCP Port no used is 4322)
Accepted connection from 127.0.0.1 student-PC 53460
JTAG Hyperterminal Started"
2) terminal (which does open a black terminal window but with no communication)
Always says " Closed TeraTerm/Hyperterminal connection "; even if the hyperterminal installed 8in my PC is running.
Is there any inbuilt hyperterminal in sdk to be invoked??
Stuck from a very long time..
MKJ
Tags (5)
