rajesh.patchala
compilation libraries
hi all,
       i was trying to generate HDL simulation files for my EDK project using SIMGEN , but i end up with this error :
ERROR:Portability:90 - Command line error: Unexpected argument[15]
   "............./simlib/EDK9.2_mti_se_nt/ISE_Lib/" found.
before i ran the SIMGEN , i have complied the simulation libraries for edk(9.2i) (model sim se 6.1) , then i ended with the following errors, are these two sets of related ... can any one please tell what they are and how  to fix them...
** Error: (vcom-13) Recompile xilinxcorelib.mem_init_file_pack_v3_2 because xilinxcorelib.ul_utils has changed.
** Error: (vcom-13) Recompile xilinxcorelib.blkmemdp_v3_2 because xilinxcorelib.ul_utils has changed.
ERROR:: Failed to execute vcom -93 -quiet -work opb_ipif_v1_23_a -f "C:/Dokumente und Einstellungen/patchala/simlib/EDK9.2_mti_se_nt/EDK_Lib/CompileListFiles/opb_ipif_v1_23_a_compile_order" :
Compiling opb_spi_v1_00_b.
thank you,
rajesh
centaur19
Rajesh,
You are trying to compile the libraries in a folder that has spaces in the name. Can you try compiling the libraries in say C:\simlib?
rajesh.patchala
hello centaur19,
     Thank you for the suggestion i have changed the path with no spaces and it worked.
thank you.,
rajesh
