create mfs file for standalone with example design
i am developing ethernet interface using ethernetlite core on customized board.i added and processor, timer, uart,ddr2.etc.then generated bit file. exported to sdk. Chose bsp project standalone, added echo server, built program.Here, i am confusing that:
connected my board to computer using JTAG. then opened XMD% console
->connect connect mb mdm
"here i dont have .mfs file, how to generate it, what is the use of it?"
cd E:/../echoserver/Debug
dow echoserver.elf
Is it right procedure to do it. or any other procedure.
Please dont recommand any doc.
i am very new toedk & sdk.
Give me clarity.
Thank you, advance
Scholar stephenm
Re: create mfs file for standalone with example design
This is needed for webs er et application,  not the echo server.the mls is the file that sits in the file system.
See xapp1026 for more info
Where can I find webserver application files?In application projects, i didn't find this Application.
Thank you advance
Scholar stephenm
This is delivered with xapp1026 in a zip file
