createhw warning in 2017.3 that was not present in 2017.2
I have an hdf that is created with 2017.3.
The exact same xsct command sequence, taken nearly verbatim from the ref manual, produces an unpleasant warning in 2017.3. What should I do to avoid that? Or is it just noise?
See the following sequence:
bash$ source /opt/Xilinx/SDK/2017.2/settings64.sh
bash$ xsct
****** Xilinx Software Commandline Tool (XSCT) v2017.2
**** Build date : Jun 15 2017-18:45:22
** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
xsct% setws .
xsct% createhw -name hw1 -hwspec hw1.hdf
Starting xsdk. This could take few seconds... done
xsct%
Compare that to the following sequence after removing all products from the previous sequence:
bash$ source /opt/Xilinx/SDK/2017.3/settings64.sh
bash$ xsct
****** Xilinx Software Commandline Tool (XSCT) v2017.3
**** Build date : Oct 4 2017-20:06:47
xsct% setws .
WARNING: [Hsi 55-1434] Error /opt/Xilinx/SDK/2017.3/data/embeddedsw/XilinxProcessorIPLib/drivers/rfdc_v2_1/data/rfdc.mdd:49 Unrecognized Option name. List of possible Option names are : DRC, DESC, COPYFILES, DEPENDS, SUPPORTED_PERIPHERALS, DRIVER_STATE, DEFAULT_OS, NAME, VERSION
INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds
hsi::open_hw_design: Time (s): cpu = 00:00:05 ; elapsed = 00:00:05 . Memory (MB): peak = 484.516 ; gain = 132.508 ; free physical = 10595 ; free virtual = 29389
xsct%
Tags (2)
This can be safely ignored. this is a new RFSoC driver added to 2017.3. There is a known issue in the MDD file
Thanks!
I still think it is strange that I get warnings from the tools while using them correctly - I can however live with that.
