Visitor vibhuthk
creating fsl ports in verilog??
i am designing a mudule and i want to connect it to microblaze using fsl links,
can anyone tell me what should i declare as my ports to connect them to fsl in xps??
Re: creating fsl ports in verilog??
you can try this XILINX appnote
www.xilinx.com/support/documentation/application_notes/xapp529_6_1.zip
http://www.xilinx.com/support/documentation/application_notes/xapp529.pdf
Thanks and Regards
Balkrishan
http://www.ece.iit.edu/~/ecasp/tutorials/microblaze_tutorial.pdf
Thanks and Regards
Balkrishan
Moving to Embedded board
Deepika.
Thanks and Regards
Balkrishan
Either you can create a wrapper and do it ot you could add it as a  pcore in side XPS.
Hope this helps.
Sikta
