cross compiling for Zedboard
In my project i have to use FFTW library which is freely available and i downloaded it. now the software which i am using is vivado SDK and it is running in centOS. I have to run my project on Zedboard which has an ARM processor and my pc has x86_64 AMD architecture. as the host and build architectures are different so it means i have to cross compile the library in order to be able to use it my project in SDK and the toolchain which i have to use is Xilinx ARM GNU/LINUX toolchain.
Can some one guide me how can i compile so that i can use it i tried many things but always had errors, like "bad ELF enterpreator" and unrecognized binary format.
Any help in this regard will be highly appreciated,
Thank you
