custom data and program sections
I am working with SDK with Kintex7 MiniModule plus reference design. In this design all sections are placed on DDR2 memory. I need to have some functions and data placed in internal BRAM memory instead DDR2 memory, to speed up performance. I know how specify new sections in *.ld script file, for example "mytext" and "mybss" are two new sections. I don't know how tell that a variable must be linked in "mybss" sections and a function must run in "mytext" section.  Are there any pragma for gnu linker?
Best Regards,
Begos
Re: custom data and program sections
I think that I can use, for example, this directive:
void example_func(void) __attribute__((section("my_section")));
Does anyone know if is it right?
begos
Anonymous
Not applicable
yes, I know this document. This document explain how modify linker script file to specify new custom sections, but I need the further step, that is  to know what are the directive or pragma to tell to the linker that a specific portion of code or data must be linked in a desired custom section. I know how do this with other toolchain (code composer studio, raisonance ,  keil, iar...) but I don't know how in SDK.
begos
begos
