custom ip to NPI, mpmc connection, clock
I am trying to connect a custom ip to mpmc to read and write from memory with NPI.
I have connected everything to the NPI ports. Now I wonder to which clock and which reset I have to connect the clock and reset from my NPI. Do i have to connect it to the PLB clock or the MPMC clock?
Can anyone help me?
Thanks in advance.
NPI is a "native" interface of the MPMC, and so must be tied to the MPMC clock.
Thank you for your quick reply!
