dborkma
data2mem with elf file: system.bit and download.bit have the same size
Hi all,
I use the following command for my ML605 Board to produce a download.bit file with the Linux kernel ELF:
data2mem -bm implementation/system_bd -p xc6vlx240tff1156-1 -bt implementation/system.bit  -bd /home/bordanie/edk/simpleImage.ml605_blubb.elf tag microblaze_0  -o b implementation/download.bit
Afterwards, the system.bit and download.bit have the same file size (xps version: 12.3). This is clearly wrong since the download.bit must contain the elf and the system.bit.
What did I do wrong?
All files are here: https://github.com/borkmann/xilinx-ml605
(Note: the Kernel ELF works fine when uploading first the system.bit and later the elf to the board, but I need a download.bit for the systemace. The system also has a BRAM where I used the kernel ELF for initialization in xps, updating the bitstream worked without error messages, but as mentioned ... both have the same size!)
Thanks for help,
Daniel
P.s.: the log says:
... (INFO messages)
Computing clock values...
Performing IP level DRCs on properties...
Running DRC Tcl procedures for OPTION IPLEVEL_DRC_PROC...
Address Map for Processor microblaze_0
(0000000000-0x07ffffff) DDR3_SDRAM mb_plb
(0000000000-0x07ffffff) DDR3_SDRAM microblaze_0_DXCL
(0000000000-0x07ffffff) DDR3_SDRAM microblaze_0_IXCL
(0x08000000-0x0800ffff) xps_bram_if_cntlr_0 mb_plb
(0x40010000-0x4001ffff) dlmb_cntlr dlmb
(0x40010000-0x4001ffff) ilmb_cntlr ilmb
(0x81000000-0x8100ffff) Ethernet_MAC mb_plb
(0x81400000-0x8140ffff) Push_Buttons_5Bit mb_plb
(0x81420000-0x8142ffff) LEDs_Positions mb_plb
(0x81440000-0x8144ffff) LEDs_8Bit mb_plb
(0x81460000-0x8146ffff) DIP_Switches_8Bit mb_plb
(0x81600000-0x8160ffff) IIC_SFP mb_plb
(0x81620000-0x8162ffff) IIC_FMC_LPC mb_plb
(0x81640000-0x8164ffff) IIC_EEPROM mb_plb
(0x81660000-0x8166ffff) IIC_DVI mb_plb
(0x81800000-0x8180ffff) xps_intc_0 mb_plb
(0x81818000-0x818180ff) xps_timer_0 mb_plb
(0x83600000-0x8360ffff) SysACE_CompactFlash mb_plb
(0x84000000-0x8400ffff) RS232_Uart_1 mb_plb
(0x84400000-0x8440ffff) mdm_0 mb_plb
... (INFO messages)
Checking platform address map ...
Initializing Memory...
Running Data2Mem with the following command:
implementation/system.bit -bd simpleImage.ml605_blubb.elf tag microblaze_0 -o
Memory Initialization completed successfully.
robn
A bitstream contains a "blueprint" that descripes how the *entire* FPGA will be programmed. This includes data that describes parts of the device that aren't used for your design; these unused parts are still saved as "unplaced", or "unrouted", but they still have to exist.
Basically, this translates into a single size bitstream for a particular device, no matter how full it is! :-)
You could have some HDL that blinks a single LED, or you could have 8 Microblazes running all sorts of RTOS-es; the bitstream for both these designs will remain the same size.
robn
tibacou
Hey
I search a kind of programm my spartan 6 I have a file bitsream and application in c language I want programme the  spartan 6 's flash. Idon't know hpw I can do with the tools of Xilinx of 14.4 or 14.2. I want load the files .bit and .elf and the system is standalon. When the supply cut the system can lauch the .bit and .elf
Do you can help me ?
Best Regards.
