Voyager
Voyager
different version of SDK launch issue with vivado batch mode
Hi Friends,
I am using Vivado 2016.4 for synth and implementation.  I have SDk of 2015.1 version .
When i use lauch_sdk , it is trying to open 2016.1 version of SDK but that is not installed.
how do i instruct to tool that choose other version of SDK in vivado batch mode.
Thank You
S Sampath kumar
Re: different version of SDK launch issue with vivado batch mode
Hi @ssampath,
This post should have been posted on the Embedded Development Tools forum.
The question is why do you use different version of SDK and vivado?
For the same project, you should use the same version for vivado and SDK (you might face issue if you don't).
Then if you source the script for SDK (sh or bat):
Xilinx/SDK/2017.3/.settings64-SDK_Core_Tools.sh
it should set up the correct PATH. If not working, check that you don't have any environment variables that point to the wrong version.
Hope that helps,
Florent
Florent
