Hi , i found code C about "
parses a BMP file and creates a filename.h file in a custom format " . But i don't understand how use it . Because I just use EDK , please you show how i can use this code for my project . I try to use this code for my project but after
download --> run XMD -->dow executable.elf-->run --> ???????????? .
#include "stdio.h"
#include "stdlib.h"
#include "string.h"
#define BUFSIZE (640*480*4)
#define TRUE 1
#define FALSE 2
/* Structure Definitions */
typedef struct {
unsigned short int type; /* Magic identifier */
unsigned int size; /* File size in bytes */
unsigned short int reserved1, reserved2;
unsigned int offset; /* Offset to image data, bytes */
} HEADER;
typedef struct {
unsigned int size; /* Header size in bytes */
int width,height; /* Width and height of image */
unsigned short int planes; /* Number of colour planes */
unsigned short int bits; /* Bits per pixel */
unsigned int compression; /* Compression type */
unsigned int imagesize; /* Image size in bytes */
int xresolution,yresolution; /* Pixels per meter */
unsigned int ncolours; /* Number of colours */
unsigned int importantcolours; /* Important colours */
} INFOHEADER;
/* Functions */
static unsigned short ReadUShort(FILE *fptr)
unsigned char b0, b1;
b0 = getc(fptr);
b1 = getc(fptr);
return ((b1 << 8) | b0);
static unsigned int ReadUInt(FILE *fptr)
unsigned char b0, b1, b2, b3;
b0 = getc(fptr);
b1 = getc(fptr);
b2 = getc(fptr);
b3 = getc(fptr);
return ((((((b3 << 8) | b2) << 8) | b1) << 8) | b0);
/* Main */
int main(int argc,char **argv)
int i,j,count,align;
int gotindex = FALSE;
unsigned char r,g,b;
HEADER header;
INFOHEADER infoheader;
FILE *outfile;
FILE *infile;
unsigned char filebuff[BUFSIZE];
/* Check arguments */
if (argc < 2) {
fprintf(stderr,"Usage: %s <filename>\n\n",argv[0]);
fprintf(stderr,"%s creates a filename.h file in the format:\n",argv[0]);
fprintf(stderr,"width,\n");
fprintf(stderr,"height,\n");
fprintf(stderr,"0x00000000,\n");
fprintf(stderr,"image data...\n");
exit(-1);
/* Open files */
if ((infile = fopen(argv[1],"r")) == NULL) {
fprintf(stderr,"Unable to open BMP file \"%s\"\n",argv[1]);
exit(-1);
if ((outfile = fopen(strcat(argv[1],".h"),"w")) == NULL) {
fprintf(stderr,"Unable to open output file \"xlogoc.h\"\n");
exit(-1);
/* Read and check the header */
header.type = ReadUShort(infile);
fprintf(stderr,"ID is: %d, should be %d\n",header.type,'M'*256+'B');
header.size = ReadUInt(infile);
fprintf(stderr,"File size is %d bytes\n",header.size);
header.reserved1 = ReadUShort(infile);
header.reserved2 = ReadUShort(infile);
header.offset = ReadUInt(infile);
fprintf(stderr,"Offset to image data is %d bytes\n",header.offset);
infoheader.size = ReadUInt(infile);
infoheader.width = ReadUInt(infile);
infoheader.height = ReadUInt(infile);
infoheader.planes = ReadUShort(infile);
infoheader.bits = ReadUShort(infile);
infoheader.compression = ReadUInt(infile);
infoheader.imagesize = ReadUInt(infile);
infoheader.xresolution = ReadUInt(infile);
infoheader.yresolution = ReadUInt(infile);
infoheader.ncolours = ReadUInt(infile);
infoheader.importantcolours = ReadUInt(infile);
fprintf(stderr,"Image size = %d x %d\n",infoheader.width,infoheader.height);
fprintf(stderr,"Number of colour planes is %d\n",infoheader.planes);
fprintf(stderr,"Bits per pixel is %d\n",infoheader.bits);
fprintf(stderr,"Compression type is %d\n",infoheader.compression);
fprintf(stderr,"Number of colours is %d\n",infoheader.ncolours);
fprintf(stderr,"Number of required colours is %d\n",
infoheader.importantcolours);
fread(filebuff,1,BUFSIZE,infile);
fprintf(outfile, "unsigned long bitmap[] = { \r\n");
fprintf(outfile, "0x%.8x, ",infoheader.width);
fprintf(outfile, "0x%.8x, ",infoheader.height);
fprintf(outfile, "0x00000000, ");
align = (infoheader.width%4) * infoheader.height;
if (infoheader.width%4 == 2) align -= 2;
for (j=infoheader.height-1;j>=0;j--) {
fprintf(outfile, "\r\n// Line %d",infoheader.height-j);
for (i=0;i<infoheader.width;i++) {
if (i%4 == 0) fprintf(outfile, "\r\n");
fprintf(outfile,
"0x%.2x%.2x%.2x%.2x, ",
0x00,
filebuff[(j*(infoheader.width)*3)+(i*3)+2+align], //R
filebuff[(j*(infoheader.width)*3)+(i*3)+1+align], //G
filebuff[(j*(infoheader.width)*3)+(i*3)+align]); //B
} /* i */
align -= infoheader.width % 4;
} /* j */
fprintf(outfile, "};\r\n\r\n");
fclose(infile);
fclose(outfile);
