Visitor jeff660209
download elf problem
i have a question to download elf file in the XMD command environment. i used Windriver VxWorks  general a vxworks.elf file ,then use elf file to download on my board.
 but appear a error message in the xmd ,this error message  tell  me :
"failed to download ELF file
ERROR<1059>:I-side memory access check failed
section,0x0001000-0x001180bf not accessible from processor i-side interface"
i don't what to solve this problem
someone can help me
thank you
jeff
Visitor bponion
Re: download elf problem
i encounter the same problem with you
have you solved this problem yet?
Have you verified address range is accessiable from the I-side of the processor?
Another you can try is open a EDK command shell, launch XMD inside of the shell by typing xmd, connect to the processor by typing either mb or ppc, and then download the elf file.
Visitor bponion
Thanks for your answer!
I will try your solution and will let you know my trial.
Visitor bponion
hi,
The problem is indeed from the address range.
Thanks for the answer!
Visitor wintermayr
Hi I got the same problem as you. How do you solve it by checking address range?
