edited peripheral error in microblaze
Initially when I made the peripherals in simply added them to microblaze and they were working correctly.
After that when I made some minor adjustments (bring some internal signals to output port for them to be accessed externally) then compiler was giving this error
ERROR:NgdBuild:604 - logical block
   'multi_rt_var_addr_0/multi_rt_var_addr_0/USER_LOGIC_I/Inst_RT_sch/XLXI_173'
   with type 'DualPortRam' could not be resolved. A pin name misspelling can
   cause this, a missing edif or ngc file, case mismatch between the block name
   and the edif or ngc file name, or the misspelling of a type name. Symbol
   'DualPortRam' is not supported in target 'spartan6'.
   'multi_rt_var_addr_0/multi_rt_var_addr_0/USER_LOGIC_I/Inst_RT_sch/XLXI_174'
   'multi_rt_var_addr_0/multi_rt_var_addr_0/USER_LOGIC_I/Inst_RT_sch/XLXI_171'
   with type 'blk_mem_gen_v4_2' could not be resolved. A pin name misspelling
   can cause this, a missing edif or ngc file, case mismatch between the block
   name and the edif or ngc file name, or the misspelling of a type name. Symbol
   'blk_mem_gen_v4_2' is not supported in target 'spartan6'.
ERROR:Xflow - Program ngdbuild returned error code 2. Aborting flow execution...
make: *** [__xps/system_routed] Error 1
I tried updating the ngc file regenerating the IP cores for the internal memory that was mentioned in the error but nothing worked.
Re: edited peripheral error in microblaze
Can you add the -sd option in the implementation options in ISE? To do this, right click on the translate in ISE, properties.
In the GUI add the path to the implementation folder in the EDK project directory.
