10-08-2020 05:37 PM - edited 10-08-2020 10:11 PM
I could not build fsbl_a53 example in Section 'Create First Stage Boot Loader for Arm Cortex-A53-Based APU' in ug1209 v2020.1.
The following error message come up:
Building target: fsbl_a53_zcu102.elf
Invoking: ARM v8 gcc linker
aarch64-none-elf-gcc -n -Wl,-T -Wl,../src/lscript.ld -L/mnt/data/SandBox/edt_zcu102_wrapper/export/edt_zcu102_wrapper/sw/edt_zcu102_wrapper/standalone_domain/bsplib/lib -o "fsbl_a53_zcu102.elf" ./src/psu_init.o ./src/xfsbl_authentication.o ./src/xfsbl_board.o ./src/xfsbl_bs.o ./src/xfsbl_csu_dma.o ./src/xfsbl_ddr_init.o ./src/xfsbl_dfu_util.o ./src/xfsbl_exit.o ./src/xfsbl_handoff.o ./src/xfsbl_hooks.o ./src/xfsbl_image_header.o ./src/xfsbl_initialization.o ./src/xfsbl_main.o ./src/xfsbl_misc.o ./src/xfsbl_misc_drivers.o ./src/xfsbl_nand.o ./src/xfsbl_partition_load.o ./src/xfsbl_plpartition_valid.o ./src/xfsbl_qspi.o ./src/xfsbl_rsa_sha.o ./src/xfsbl_sd.o ./src/xfsbl_translation_table.o ./src/xfsbl_usb.o -Wl,--start-group,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilffs,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilpm,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxilsecure,-lxil,-lgcc,-lc,--end-group
/mnt/data/XilinxTools/Vitis/2020.1/gnu/aarch64/lin/aarch64-none/x86_64-oesdk-linux/usr/bin/aarch64-xilinx-elf/aarch64-xilinx-elf-ld.real: address 0xfffe9e18 of fsbl_a53_zcu102.elf section `.dup_data' is not within region `psu_ocm_ram_0_S_AXI_BASEADDR'
/mnt/data/XilinxTools/Vitis/2020.1/gnu/aarch64/lin/aarch64-none/x86_64-oesdk-linux/usr/bin/aarch64-xilinx-elf/aarch64-xilinx-elf-ld.real: section .handoff_params VMA [00000000fffe9e00,00000000fffe9e87] overlaps section .dup_data VMA [00000000fffe8c00,00000000fffe9e17]
collect2.real: error: ld returned 1 exit status
make: *** [makefile:38: fsbl_a53_zcu102.elf] Error 1
The hardware platform is zcu102 and it was created follow the process in Chapter 2 of the same document (ug1209).
The Vitis and Vivado are all v2020.1.
No problem to follow the other examples in Chapter 3 that using the same zcu102 xsa.
Thanks for help.
10-09-2020 02:35 PM
Those messages look like the ones you see when the FSBL is too big to fit in on-chip RAM. Did you enable debug in the FSBL, or change any other settings?
10-11-2020 04:00 PM
The debug was enabled in the example, but the optimisation flags also added.
Since I just following the ug1209 official guide on zcu102 which was requrest in the tutorial, I didn't expect to receive these kind of errors.
By the way, I also tried the example on zcu111 platform, and there is NO such errors. All went through.
I think you are right. It seems that the zcu102 do not have enough FSBL RAM space to complete the example in the tutorial.
Please correct me if I missed anything here.
10-13-2020 04:00 PM
Hi @liuyz
Can you see if the following helps?
10-13-2020 04:36 PM
hi @marcb ,
The .dup_data section is available in the lscript.ld by default. And it is allocated to psu_ocm_ram_0_S_AXI_BASEADDR.
It is defined as
.dup_data (ALIGN(64)): {
__dup_data_start = .;
. += __data_end - __data_start ;
__dup_data_end = .;
} > psu_ocm_ram_0_S_AXI_BASEADDR
and the memory regin is defined as
MEMORY
psu_ocm_ram_0_S_AXI_BASEADDR : ORIGIN = 0xFFFC0000, LENGTH = 0x00029D00
psu_ocm_ram_1_S_AXI_BASEADDR : ORIGIN = 0xFFFE9E00, LENGTH = 0x00000200
psu_ocm_ram_2_S_AXI_BASEADDR : ORIGIN = 0xFFFF0040, LENGTH = 0x0000FDC0
Also,
_STACK_SIZE = DEFINED(_STACK_SIZE) ? _STACK_SIZE : 0x2000;
_HEAP_SIZE = DEFINED(_HEAP_SIZE) ? _HEAP_SIZE : 1024;
These are all default values when following the ug1209 tutorial.
Please let me know where could be the problem. Thanks.
10-14-2020 04:20 PM
Hi @liuyz
Can you upload the exported Vitis archive to allow the community to help further? Also, what operating system is Vitis installed on?
10-25-2020 05:38 PM
Hi @marcb ,
I created FSBL with ZCU111 and the errors are gone.
To reproduce the errors, just follow the tutorial ug1209 and ZCU102.
Basically, same procedure for ZCU111 is okay, for ZCU102 will report errors.
11-02-2020 03:56 PM
Hi @liuyz
Was this done on a Windows machine? I didn't see the errors using Linux while building the platform for chapter 3 of UG1209.
Did you happen to reset the BSP sources, or update the XSA?
11-03-2020 02:09 PM
Hi @marcb ,
I'm on RHEL 7.6.
I didn't reset the BSP or update the XSA.
Are you running on RHEL or Ubuntu? ZCU111 or ZCU102?
Thanks a lot.
11-03-2020 07:58 PM
hi @marcb ,
After exclude the NAND and QSPI boots and SECURE feature, I can now build the fsbl_a53 example.
