error in sdk(urgent)
sir, i am using xilinx sdk14.4. i am using ucos1.11.i am using zynq board. i already set my stdout port on ps7_uart1. afterthat, i am getting the same error. undefined reference in outbyte on write.c file. i attached my error postion also.only in the write .c file ,these errors are coming.please help me quickly..
Description Resource Path Location Type
more undefined references to `outbyte' follow write.c /mac_project_bsp/ps7_cortexa9_0/libsrc/ucos_standalone_v1_11/src line 84 C/C++ Problem
undefined reference to `outbyte' write.c /mac_project_bsp/ps7_cortexa9_0/libsrc/ucos_standalone_v1_11/src line 60 C/C++ Problem
undefined reference to `outbyte' write.c /mac_project_bsp/ps7_cortexa9_0/libsrc/ucos_standalone_v1_11/src line 82 C/C++ Problem
undefined reference to `outbyte' write.c /mac_project_bsp/ps7_cortexa9_0/libsrc/ucos_standalone_v1_11/src line 84 C/C++ Problem
Thank you
Re: error in sdk(urgent)
I have read about this issue occurs when the C-code contains "printf-" statements and a peripheral has not been defined as "std_out" and "std_in".
Could you check the answer record http://www.xilinx.com/support/answers/14448.html if it helps you?
Praveen
Other reason could be the BSP might got broken.
Delete the BSP and replace it with a new one..
Alternatively, try including  xil_io.h in your application manually.
Praveen
