Observer clmnt_lbrr
export hardware flow is not supported for design with no block diagram instances
Hi every one,
During my internship I work on a project started by someone else. I've made lot of tutorial in order to understand how vivado and the SDK works, but on this project the simple feature of exporting hardware doesn't work...
If you have any idea of answer that would be helpfull.
I have attached a screenshot of the error.
clmnt_lbrr
Vivado version: 2014.4
Board: KC705
Re: export hardware flow is not supported for design with no block diagram instances
Please assemble the mcs, clock generator and other IPs in an IPI project i.e. block design and have the RTL logic wrapper around it if any. Then the tool will detect the block design and will export to SDK.
Refer to page 71 in http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug940-vivado-tutorial-embedded-design.pdf
Praveen
Please check the below thread.
http://forums.xilinx.com/t5/Embedded-Development-Tools/Vivado-2014-2-can-t-export-to-SDK/td-p/480754
Thanks,Vijay
Scholar austin
Please post your log file.  It will contain the reasons why you get this error.
And, read the last post in the thread suggested above.
Austin Lesea
Principal Engineer
Xilinx San Jose
Observer clmnt_lbrr
here is the log file,
# Vivado v2014.4 (64-bit)
# SW Build 1067303 on Wed Nov 12 17:04:19 MST 2014
# IP Build 1068446 on Thu Nov 13 19:40:58 MST 2014
# Start of session at: Tue Jun  2 16:37:00 2015
# Process ID: 17119
# Log file: /user/erasmus/cluberry/vivado.log
# Journal file: /user/erasmus/cluberry/vivado.jou
start_gui
open_project /user/erasmus/cluberry/Desktop/project/fin-math/workspaces/complete_dp/complete_dp.xpr
Scanning sources...
Finished scanning sources
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/cadtools/xilinx/2010/Vivado/2014.4/data/ip'.
open_project: Time (s): cpu = 00:00:18 ; elapsed = 00:00:12 . Memory (MB): peak = 5751.062 ; gain = 71.664 ; free physical = 1921 ; free virtual = 18939
ERROR: [Vivado 12-4157] Export Hardware flow is not supported for designs with no block diagram instances
I've already seen this topic, but it is not speaking about the same error
clmnt_lbrr
Observer clmnt_lbrr
Moreover, the implementation is completed but with time constrains errors...
Here is attached the log file of the Systhesis and Implementation if it could help
clmnt_lbrr
Praveen
Observer clmnt_lbrr
So I should make a block with mcs and clockgen, and make a wrapper of a wrapper? Or should I just make a block design with the mcs, clockgen and the pricer's file?
clmnt_lbrr
I meant block design.
Praveen
Observer clmnt_lbrr
ok, but can we do a block design from file that are already under a wrapper. A kind of "select the 3 files" -> right clic -> creat a block design?
clmnt_lbrr
Observer clmnt_lbrr
@pvenugo wrote:
I think it's the good way to solve the problem but I need to make lot of modifications to the project as it is now, I'll send you feedback when that would have been done.
clmnt_lbrr
Observer clmnt_lbrr
Since the last time I have change the structure of the project as @pvenugo advised me.
I now have no problem to export, at least to windows shows up in vivado, but the SDK doesn't open as it should be
here is the picture of the structure and the SDK problem
It seems that no hardware are exported, do you see anything not normal?
clmnt_lbrr
Observer clmnt_lbrr
So I have open an other project Vivado and SDK it was working. I have retry the first project and it work now...
clmnt_lbrr
So, did you get the design work and exported to SDK without any issue?
Praveen
Observer clmnt_lbrr
Yes the design seems to work (I have others things to check which are not relative to this section), I managed to export to SDK and programed the board without others problems than describe in my posts.
note : I have update Vivado to 2015.1 during the redevelopment of the project, if it has a importance for future reader.
clmnt_lbrr
OK, if this post has solved your issue, please mark it as accepted solution.
Praveen
Observer clmnt_lbrr
already done!
clmnt_lbrr
